Sergio_Magra
Feb 19, 2013Filename is seeing as parameter and applied a SQL Injection signature
Hi, the ASM (9.4.4) have a false positive by detecting the filenames as parameter and applying the following SQL injection signature:
False Positive: SQL-INJ "--" (SQL comment) (Parameter)
Please see the example below:
POST /app/send.asp?X=6066919 HTTP/1.1
Content-Length: 7374
Accept: */*
User-Agent: Mozilla/4.0 (compatible; Win32; WinHttp.WinHttpRequest.5)
Host: www.site.com.ar
Connection: Keep-Alive
Cookie: ASPSESSIONIDCSDQQDSB=BEDCIDEDOJKBLNGBAIIOAFNA; TSea8a3d=7c60168503bfcf24ce0c31dd15b7ce389035dffc2e4c5e3850feedb0226eee961c71a653
X-Forwarded-For: 16.19.1.21
-----------------------------7d117c2c490276
Content-Disposition: form-data; name="file1"; filename="C:\sending\TEMP\b00007_20130122.rta"
Content-Type: text/plain
22/01/2013@00007@0000000001@0001637111@03@00253400816631@1099,00@22/01/2013@S@80@20930251098@@@@
22/01/2013@00007@0000000001@0002605873@03@00225400140366@0,02@22/01/2013@S@80@20100373964@@@@
22/01/2013@00007@0000000001@0002938678@03@00064400561979@26,91@22/01/2013@S@80@27201659596@@@@
22/01/2013@00007@0000000001@0003028006@03@00250400918981@919,60@22/01/2013@S@80@20214789176@@@@
How to avoid this?
Thanks and Best regards
- Mike_Maher
Easy way would be to just disable that Signature on the Parameter - Sergio_Magra
Thanks for the answer.
But, if it is not a parameter, I will need to disable the signature globally?On the other hand, could it have relationship with defining the parameter as binary in order to avoid being scanned?
Thanks and Best regards - Torti
Cirrus
why contains the parameter filename the complete path? It should only contain the name.
How is the detailed violation?
Shouldn't be 'file1' the binary?
Yes, you can set filename as parameter, to disable signature scanning. Then, only some base signatures are scanned.
But you cannot disable the complete signature scanning for a single parameter.
