Failover visibility
If an LTM fails over, will a user notice the drop if the user is connected over SSL? Will the user have to log in again after failover on an SSL page?
Thanks.
- Ryannnnnnnnn
Altocumulus
Do you have connection mirroring enabled?
- Ryan_80361
- pete_71470
Terminated SSL doesn't mirror but unterminated SSL can. SSL for a virtual is terminated on the appliance if you have client ssl profile attached.
Perhaps more important than mirroring for you might be persistence mirroring. During a failover all terminated SSL sessions are dropped, and without compatible persistence being mirrored (or cookie persistence without mirroring) there is a good chance clients connecting to the newly Active unit will find themselves balanced to a different pool member (causing users to find they have to log in again) because the newly Active unit wouldn't be aware of the previous load balancing decision.
