Ray_Ebersole_13's avatar
Ray_Ebersole_13
May 18, 2014
Solved
Failover Error - SOD Configuration CRC does not match
We did a failover to our 2 F5 Big-IP this morning because all applications on the 1 unit started to run slowly until they started to just timeout. After the failover all the applications started working correctly, so we did a commandline restart of the 1 unit and moved all traffic back to the 1. It is now running correctly, but when we finished the restart the Dashboard shows the error:
"SOD Configuration CRC does not match"
I understand a CRC error, but I have not found anything in any of the F5 documentation that describes the Failover (SOD) error message.
Could anyone point me to some documentation on the issue?
Thanks.....Ray
  • it is introduced in 11.4.0. when traffic-group related is changed, sod will calculate crc and include in the sod message to peers.
    ID410439 - SOD should log CRC disagreement in var/log/ltm
