JQUINONES82NB's avatar
JQUINONES82NB
Jun 11, 2019
failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
Trying to setup SSL offloading for a web socket application and I'm receiving
websocket.js:118 WebSocket connection to 'wss://x.x.x.x:4000/socket.io/?EIO=3&transport=websocket' failed: Error in connection establishment: net::ERR_SSL_PROTOCOL_ERROR
I have two vips. 80 and 443 with ssl offloading. There an option for websockets and I have applied
if { [string tolower [HTTP::header Upgrade]] contains "websocket" } {
HTTP::disable
log local0. ">>WebSocket from [IP::client_addr]"
  • Hi,
    You mentioned an option for websockets. Are you referring to the websockets profile? If not then you may want to try applying that profile to your virtual servers. It has it's own "WebSocket Profile" section in the virtual server settings. If you haven't enabled that then it may be worth a try.
    K14754: BIG-IP support for the WebSocket protocol
    https://support.f5.com/csp/article/K14754
