reddev12's avatar
reddev12
2 years ago
f5 token based authentication using uri module throw error
using below yml file with header as below and token is variable authx . error i am getting is "authx is undefined"
is the header correct ?
- name: "{{ name }}"
uri:
url: "{{ url }}"
method: "GET"
headers:
X-F5-Auth-Token: "{{ authx }}"
validate_certs: "no"
status_code: "{{ status|default(200) }}"
timeout: 60
ignore_errors: True
delegate_to: localhost
JRahm
  • what tool is this yaml for and how is it being used?
    • reddev12's avatar
      reddev12
      remotely we will execute the ansible script ...and token is created from other script and kept as ansible vars ...just want to place that token variable in this yaml
      url will contain f5 rest api
      • JRahm's avatar
        JRahm
        Icon for Admin rankAdmin
        authx variable isn't populating, so that will need to be solved before you can troubleshoot anything else. what does that playbook look like?
