Vijay_1982_1648's avatar
Vijay_1982_1648
May 20, 2016
F5 snmp trap for node and pool members
Hi All,
we are planning to enable SNMP trap for node and pool members up and down. so how to start and can someone provide the implementation plan. I have tried to read multiple documents but no luck. Kindly help on.
  • nathe's avatar
    nathe
    We would probably need to understand more your requirement and what may not be working.
    The examples you give should already have SNMP traps. See /var/run/bigip_error_maps.dat to map a log entry to alert and then see /etc/alertd/alert.conf to map this to an OID and a SNMP trap.
    Then you should be able to configure a trap destination in the GUI to send them to a server.
    See if these links help further: https://support.f5.com/kb/en-us/solutions/public/6000/400/sol6420.html
    https://support.f5.com/kb/en-us/solutions/public/11000/100/sol11127.html
    Hope this helps,
    N
  • Pre-configured SNMP traps are contained in the /etc/alertd/alert.conf file. F5 does not recommend, or support, the addition or removal of traps or any other changes to the alert.conf file.
    Custom, user-defined SNMP traps should be defined in the /config/user_alert.conf file.
    Depending on what you what to monitor, you can add it to user_alert.conf, example:
    alert BIGIP_LOG_WARNING ".*No members available for pool" {
            snmptrap OID=".1.3.6.1.4.1.3375.2.4.0.201";
            email toaddress="[email protected]"
            fromaddress="root"
            body="No members available for pool"
