F5 SDK usage with ASM
Where can I get sample code for using ASM with F5 SDK I ran the following code.
from import BigIP import requests from requests.packages.urllib3.exceptions import InsecureRequestWarning
requests.packages.urllib3.disable_warnings(InsecureRequestWarning)
mgmt = BigIP("192.168.199.241", "admin", "admin")
Get a list of all pools on the BigIP and print their names and their
members' names
pools = mgmt.tm.ltm.pools.get_collection() for pool in pools: print pool.name for member in pool.members_s.get_collection(): print member.name
Create a new pool on the BIG-IP
mypool = mgmt.tm.ltm.pools.pool.create(name='mypool', partition='Common')
Load an existing pool and update its description
pool_a = mgmt.tm.ltm.pools.pool.load(name='mypool', partition='Common') pool_a.description = "New description" pool_a.update()
Delete a pool if it exists
if mgmt.tm.ltm.pools.pool.exists(name='mypool', partition='Common'): pool_b = mgmt.tm.ltm.pools.pool.load(name='mypool', partition='Common') pool_b.delete()
I got the following result.
Traceback (most recent call last): File "test.py", line 10, in pools = mgmt.tm.ltm.pools.get_collection() File "/usr/lib/python2.7/site-packages/f5/bigip/mixins.py", line 102, in getattr raise AttributeError(error_message) AttributeError: 'f5.bigip.BigIP'>' object has no attribute 'tm'
- Anesh
Cirrocumulus
- Anesh
Cirrocumulus
can you provide the output of the below code
from f5.bigip import ManagementRoot mgmt = ManagementRoot("192.168.199.241", "admin", "admin") pools = mgmt.tm.ltm.pools.get_collection() for pool in pools: print pool.name for member in pool.members_s.get_collection(): print member.nameAlso when pasting code, please ensure to keep formatting for readability
- Jae_Hong_Kim_32
I executed the following codeimport requests from requests.packages.urllib3.exceptions import InsecureRequestWarning
from import ManagementRoot
mgmt = ManagementRoot("70.60.207.94", "admin", "admin")
collection = mgmt.tm.asm.get_collection()
for anobject in collection:
print anobjectp_collections = mgmt.tm.asm.policies_s.get_collection() for p_object in p_collections:
print p_object.name print p_object.id print p_object.kind print p_object.selfLink print p_object.allowedResponseCodes policy=mgmt.tm.asm.policies_s.policy.load(id=p_object.id)I got the following results
{u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} {u'reference': {u'link': u''}} rest-api-07 pwlpR2LJzxplAjAR3lp10g tm:asm:policies:policystate [400, 401, 404, 407, 417, 503]
All is good so far.
The following REST API would pass the Request data for arguments. I am trying to figure out how to the equivalent (pass arguments) the using using the F5 SDK
https://{{big_ip_a_mgmt}}/mgmt/tm/asm/policies?ver=12.1.0 Request Data { "fullPath":"/Common/rest-api_12", "active":"true", "virtualServers":[], "enforcementMode": "transparent", "description":"none", "applicationLanguage":"utf-8", "policy-builder":"disabled", "learningMode":"manual", "stagingSettings": { "signatureStaging": true, "placeSignaturesInStaging": false, "enforcementReadinessPeriod": 7 } }
- Anesh
Cirrocumulus
That would be a new question don't you think, as i already helped with the error you are facing in your code which was the original question, Please accept the answer and open a new question
