Iman's avatar
Iman
Dec 19, 2021
F5 product LOM check
Hello,
I want to know is there any tools or access to check the F5 product LOM ?
Because when I offer the solution based on F5 product, I want to check the requirement and LOM before sending to customer.
Best Regards.
  • Not sure what you are looking for, but if it's about Lights-Out Management on the F5 (AOM) here is some documentation:
    https://support.f5.com/csp/article/K9403
  • Iman's avatar
    Iman
    Thank you very much for your reply.
    I mean when I suggest a solution based on F5 product, customers request a LoM (List of Materials) to purchased them from F5.
    I want to check the hardware and software requirements before sending the LoM. Something like Cisco Build & Price.
    Best Regards.
