F5 LTM is keep on rst packet to pool member.
This is little tricky for me as I have two pools and applied conditional rule in VS. Like if condition match's then Pool1 else Pool2. But as soon as connection towards Pool2 breaks (or Pool member in pool2 send RST packet) then client break both connections for Pool1 and Pool2. Rather in any pool if pool member goes down then F5 never send RST packet to client rather and continue connection to another available pool member. Please help me out to mitigate this issue" how can I prevent rst packet towards client.
/Regards Amit Grover 8527000635
Hi Amit,
if the real server unexpectly resets the connection, but is not yet marked as down by the health monitor, then you could try to catch this event using the LB::failed event.
when CLIENT_ACCEPTED { set retries 0 } when LB_FAILED { if { $retries < [active_members [LB::server pool]] } { LB::mode rr LB::reselect incr retries } }For further information on this topic I'd like to recommend the following kb articles...
https://support.f5.com/kb/en-us/solutions/public/10000/600/sol10640.html
https://support.f5.com/kb/en-us/solutions/public/10000/300/sol10386.html
Cheers, Kai
