jjgonzalez_4399
Nov 04, 2010F5 LTE VM with VSPHERE ESX
Hi.
To probe our F5 lte virtual machine, i've imported it to the virtual center 4.0.
The question is that i only see the interfaces 1.1 and 1.2 as UNINITIALIZED. Our virtual F5 has the version 10.1.
Someone can help me¿?...
Thanks.
- qe_102628
http://support.f5.com/kb/en-us/products/big-ip_ltm/releasenotes/product/relnotes_ve_10_1_0.html?sr=10975757
Status of virtual network interfaces (CR126854-1)
The BIG-IP system reports the status of host-only network interfaces as UNINITIALIZED, even though the interfaces are still functioning normally. - jjgonzalez_4399
Hi!.
Thanks for the replay but doesn't function. Now i finishied the installation wizard. And i've created one vlan and self ip. And i cant make ping to that ip, and i think that is for the unintialez interface. Its possible¿?.
Thanks. - qe_102628
Though the message appears, the UNITIALIZED status probably isn't the issue. (I won't say it's impossible, it's just unlikely for VE )
If you're able to ping the self-ip from the BIG-IP itself, then I'd double check the network mappings and IP configurations. That's usually the cause of traffic not working correctly when setting up a new virtual machine ( at least, in my experience )
this is sort of covered in the getting-started documentation and videos that have been created. Here's a few links that I could find for you:
Here's Colin's guide on getting started with BIG-IP VE:
http://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/1082329/BIG-IP-LTM-VE-What-is-it-Where-do-I-start-Why-is-everyone-so-excited.aspx
Here's two getting started with BIG-IP VE videos:
http://devcentral.f5.com/weblogs/dctv/archive/2010/02/16/big-ip-ltm-ve-get-started-with-a-walkthrough-from-pd.aspx
http://www.youtube.com/watch?v=Li9WO2M2YLY - George_Watkins_Historic F5 AccountHere is another video tutorial I did as well: http://devcentral.f5.com/weblogs/watkins/archive/2010/10/06/installing-ltm-ve-on-vmware-esxi.aspx
-George - jjgonzalez_4399
Thank you watkins for the video. Its very usefull.
Im traying to make the same in my net. I've got two networks 172 and 100.
Mgmt: Interface in net 100 with vlan id auto.
Interface1.1: Interface in net 172 with vlan id auto.
And now at this point, i can't make ping to the self ip create with the interface 1.1. What's the probem can be?.... - George_Watkins_Historic F5 AccountIt is almost something with the ESXi/BIG-IP networking config. Jason did a fantastic job of explaining how to get things working with this blog post: http://devcentral.f5.com/weblogs/jason/archive/2010/02/16/if-you-havent-yet-downloaded-the-big-ip-ltm-ve.aspx
I learned a lot from that post and it has helped me solve a few problems of my own. Best of luck,
George
