satish_txt_2254's avatar
May 30, 2017
F5 looping SIP ACK packet over and over
F5 sending ACK over and over to SIP proxy server in response of 200 OK and later after max out request SIP Proxy dropping packets, it's very strange behavior, following is pcap of SIP request. You can see in last 3 ACK (there are many but i capture only 3 for this question)
70.xx.xx.202 - SNAT IP 70.xx.xx.180 - VIP Address 70.xx.xx.29 - SIP Server
U 70.xx.xx.29:5060 -> 70.xx.xx.202:4371
SIP/2.0 100 trying -- your call is important to us.
Via: SIP/2.0/UDP 10.0.30.101:5060;branch=z9hG4bK-38590-1-0;rport=4371;received=70.xx.xx.202.
To: service .
Call-ID: [email protected].
CSeq: 1 INVITE.
Content-Length: 0.
SIP/2.0 200 OK.
Record-Route: .
Via: SIP/2.0/UDP 10.0.30.101:5060;rport=4371;received=70.xx.xx.202;branch=z9hG4bK-38590-1-0.
To: service ;tag=a6a1c5f60faecf035a1ae5b6e96e979a-3c64.
CSeq: 1 INVITE.
Record-Route: .
Content-Type: application/sdp.
Contact: .
Content-Length: 321.
P-hint: DIRECT-RTP.
v=0.
o=- 3705165012 3705165012 IN IP4 74.xx.xx.28.
s=session.
c=IN IP4 74.xx.xx.28.
t=0 0.
m=audio 18424 RTP/AVP 0.
a=rtpmap:0 PCMU/8000.
a=sp_media_cookie:4ac9631c1f904ac9631c1f9a014ac9631c47f8.
a=candidate 900568881 1 pas900568881 UDP 1.0 74.xx.xx.28 18424.
a=sp_chan_type:echo.
a=sp_max_gain:1.700000.
a=sp_rtcp:0.
U 70.xx.xx.202:4371 -> 70.xx.xx.29:5060
ACK sip:[email protected]:5060 SIP/2.0.
Via: SIP/2.0/UDP 10.0.30.101:5060;branch=z9hG4bK-38590-1-5.
CSeq: 1 ACK.
Contact: sip:[email protected]:5060.
Max-Forwards: 70.
Subject: Performance Test.
Content-Length: 0.
P-hint: PROXY-RTP..
Record-Route: .
U 70.xx.xx.202:8553 -> 70.xx.xx.29:5060
Record-Route: .
Record-Route: .
Via: SIP/2.0/UDP 70.xx.xx.29:5060;branch=0.
Via: SIP/2.0/UDP 10.0.30.101:5060;rport=4371;received=70.xx.xx.202;branch=z9hG4bK-38590-1-5.
CSeq: 1 ACK.
Contact: sip:[email protected]:4371.
Max-Forwards: 16.
Content-Length: 0.
P-hint: PROXY-RTP..
Record-Route: .
P-hint: PROXY-RTP.
P-hint: NON-LOCAL.
Record-Route: .
Record-Route: .
Record-Route: .
Record-Route: .
Via: SIP/2.0/UDP 70.xx.xx.29:5060;rport=8553;received=70.xx.xx.202;branch=0.
CSeq: 1 ACK.
Contact: sip:[email protected]:8553.
Max-Forwards: 15.
Content-Length: 0.
P-hint: PROXY-RTP..
Record-Route: .
P-hint: PROXY-RTP.
P-hint: NON-LOCAL.
P-hint: PROXY-RTP.
P-hint: NON-LOCAL.
  • Hi Satish,
       The request URI in ACK is in-correct it has to be set what is there in Contact header of 200 OK.
    Syed Nazir
    • satish_txt_2254's avatar
      satish_txt_2254
      Icon for Cirrus rankCirrus
      I am using SIPp scenario to test some stuff and found F5 looping ACK, Do you know how to figure out what could be wrong? following is my scenarios file ACK section.
            ACK sip:[service]@[remote_ip]:[remote_port] SIP/2.0
            Via: SIP/2.0/[transport] [local_ip]:[local_port];branch=[branch]
            From: "anon" <sip:[email protected]:[local_port]>;tag=[pid]SIPpTag00[call_number]
            To: [service] <sip:[service]@foo.example.com:[remote_port]>[peer_tag_param]
            Call-ID: [call_id]
            CSeq: 1 ACK
            Contact: sip:anon@[local_ip]:[local_port]
            Max-Forwards: 70
            Content-Length: 0
            P-hint: PROXY-RTP.
            User-Agent: sipp
  • Hi Satish,
    You may have to modify SIPp as below
    </send></p> <pre><code> ACK [$contact] SIP/2.0 Via: SIP/2.0/[transport] [local_ip]:[local_port];branch=[branch] From: "anon" <sip:[email protected]:[local_port]>;tag=[pid]SIPpTag00[call_number] To: [service] <sip:[service]@foo.example.com:[remote_port]>[peer_tag_param] Call-ID: [call_id] CSeq: 1 ACK Contact: sip:anon@[local_ip]:[local_port] Max-Forwards: 70 Subject: Performance Test Content-Length: 0 P-hint: PROXY-RTP. User-Agent: sipp
    Syed Nazir
      satish_txt_2254
      Thanks! but look like
      tmp
      variable is missing somewhere to define..
      sipp -sf foo.xml -i 10.0.0.100 -d 1 -l 1 -m 1 -r 1 proxy.example.com
      2017-06-16  15:47:49.584341 1497642469.584341: Variable $tmp is referenced 1 times!
      I am wondering what if some bad client send this kind of header to my proxy? is there any good solution we can use in iRules on F5 which can take care of it.. instead of fixing sipp..
