Heikki_Pesonen_'s avatar
Heikki_Pesonen_
Jul 12, 2011
F5 load balancing for Lync Server 2010 Edge servers
Hello,
has anyone done Lync Server 2010 Consolidated Edge pool with F5 load balancing and is it also working ok with SSL offload in F5?
We are having trouble with that configuration ( same error without SSL offload ), Lync Edge server send Reset package to F5 keep alive handshake package immediately. We have followed the F5 documentation for Lync Server load balancing. But still we have state of link as red.
Best regards,
Heikki
  • Helen_Johnson_1's avatar
    Helen_Johnson_1
    Historic F5 Account
    Hello Heikki,
    Without much information, the issue you're experiencing is a bit tricky to diagnose on the forum. Have you called support to open a case? I think that would be a good next step, especially since you followed our documentation and things aren't working as you expected.
    Cheers,
    Helen
    Helen_Johnson_1
    Historic F5 Account
    Hello Heikki,
    Cheers,
    Helen
