Drew_357798's avatar
Drew_357798
8 years ago
F5 Legacy Images
I am currently trying to upgrade an older F5 from version 9.4.6 to 10.2.1 and I cannot find the images for the legacy installs. Does any know where I can find them?
  • The older images were removed from the downloads site and are no longer available. If you are running software that is under hardware support you should be able to run at least 12.x (there are only two exceptions I know of). See
    https://support.f5.com/csp/article/K9476
    Version 10 has not seen any software development (or security patching) since 2015, and the last security patch for version 9 was cut in 2012. As such both versions should be considered insecure. I would suggest you pick a software version that is under software development. See
    https://support.f5.com/csp/article/K5903
