Josh_41258's avatar
Josh_41258
May 06, 2010
F5.IsHandler.dll help
Is anyone using the F5.IsHandler.dll module on IIS7/7.5 boxes to use the WMI monitor? We are unable to get this working in Windows 2008 R2 using IIS 7.5.. Would love some pointers.
  • I assume you are referring to the F5XForwardedFor.dll X-Forwarded-For ISAPI filter.
    I've tested this on Win2k8 with IIS7 but I don't have Win2k8R2 with IIS7.5 to test this on. Are you using the ISAPI filter or the new native HTTP Module? I do know that IIS is going away from the ISAPI model so if you haven't tried it, I'd recommend taking the HTTP Module for a spin. The functionality is the same, just the interface to IIS is different. Details are on my blog at:
    http://devcentral.f5.com/weblogs/Joe/archive/2009/12/23/x-forwarded-for-http-module-for-iis7-source-included.aspx
    -Joe
  • No, I am referring to F5.IsHandler.dll. This is the library that F5 provides for WMI monitoring for Dynamic Load Balancing.
    • keith_varga_107's avatar
      keith_varga_107
      Also, after adding the wmi monitor to my 10.2.4 F5, i cannot see it as a choice of monitors in my pool configuration. any idea why its missing?
  • I see that this is an old thread.
    Were you able to resolve the issue?
    I am experiencing the same 404.4 issue with the F5 RealServer on IIS 7.5
