Subrun's avatar
Subrun
Oct 07, 2019
Solved
F5 is not working as proxy solution - Need Help
In our scenario we are sending traffic to F5 from host 10.7.3.225 on port 21 on F5 VIP 10.8.10.85. F5 should forward that traffic to backend server 10.8.5.25 on port 7021 but it's forwarding it on port 21. In pool, node and monitor i am using port 7021 but still it's forwarding traffic on port 21.
Virtual server is configured as standard server. Backend and monitor are configured as tcp 7021.
Below is the expected traffic flow which is not working
10.7.3.225:21>>>10.8.10.85:21>>10.8.5.25:7021
Below is the tcpdump as the backend node is listening on port 7021 but as it's not getting traffic on port 7021 it's sending back Reset packet on VIP
just FYI 10.8.5.20 is the self ip. If you see the packet from 10.8.5.20 to 10.8.5.25 it's sending with localport=21
Can you please help waht's wrong in my config and if you have query to understand the flow please let me know. Thank you in advance.
  • Sure, as soon as you post as sanitised virtual server configuration. Output the configuration using tmsh list ltm virtual <virtual name> , sanitise the output to remove customer identifiers and post a gist/hastebin/pastebin link to it here.
  • Subrun's avatar
    Subrun
    Thanks for your help it was Port Translation not enabled...
