F5 GTM and Wide IP
we are thinking about deploying a GTM/LTM solution for our 2 active/active DCs with 1 GTM and 2 LTMs in each.
A DNS server will delegate to the GTM part of the global domain. And this is the configuration we are thinking to put:
-A record that defines the domain name and IP address of each GTM
gtm1.wip.example.com IN A 1.1.1.1 gtm2.wip.example.com IN A 2.2.2.2
-NS record that defines the delegated zone for which the GTM’s will be responsible
wip.example.com IN NS gtm1.wip.example.com wip.example.com IN NS gtm2.wip.example.com
-CNAME records to forward requests to the wide IPs (GTM IPs).
www.example.com IN CNAME www.wip.example.com
And here are the steps we think it will happen:
1- The user requests www.example.com and the requests goes to the DNS server that owns www.example.com
2- DNS server replies to the user saying, go to the CNAME, www.wip.example.com
3- The client will request www.wip.example.com that points to gtm1.wip.example.com and gtm2.wip.example.com
4- Once the GTM receives the request it will respond with the Wide IP
Our questions are:
1- is 1.1.1.1 and 2.2.2.2 the Self IPs of the GTMs?
2- Will the GTM reply to the user request with the Wide IP or the VIP of the LTMs?
3- Will the user have the VIP of the LTM in any action?
4- in case the user only has the WIP, it means that all the traffic going to the user wil go first to the LTM (through SNAT) and then to the GTM, and from the GTM to the user?
Thank you very much for the help.
regards,
SANTSboy
- Matt_Dierick
Employee
[Matt] Nop. 1.1.1.1 and 2.2.2.2 are the listeners on port 53.
[Matt] The wide IP is the hostname requested. GTM answer with the LTM's Virtual Servers (the VIPs). GTM answers with the translated public address is needed.
[Matt] When GTM has answered with the right VIP, user starts a connection to that VIP related to www.example.com
[Matt] the workflow : users requests DNS type A for www.example.com. DNS server (behind LTM or not) uses CNAME to make the request to the GTM listener address IP (1.1.1.1 or 2.2.2.2). GTM check in his configuration if a wideIP is equal to www.example.com. If yes, GTM answer with a Record Type A to the users corresponding to the right LTM VIP (translated or not).
- santsboy_145140
Thank you very much Mattieu, now it is clear.
Regards,
SB
- claudio_elorza_
Hi brother, i need also configure gtm for subdomain with wideip, you have guide or step. for create subdomain in gtm is necesary zone runner?
- vj_singh_177738
Hi, I am new for GTM. could you please let me know a document which I can refer for its understanding. Thanks
- dryk_00
Hello,
is it possible to load balance on GTM one FQDN that is configured for two different services? Example. Two DCs A nd B. In each DC two VIPs A: 10.10.10.10:8443 and 8080, DC B: 10.10.11.10:8443 and 8080. One fqdn for both VIPs ex. . Is this possible?
