Blue_whale
Cirrocumulus
Aug 30, 2021F5 failover best practice ?
Hi Team ,
For F5 failover from active to standby which option should we use? and what is the impact of using both the options ?
1.Using "Force standby option"
2.Failover using Preferred device Order and then Load aware .
- Fallout1984
Cirrocumulus
It may help if you note the version of software you're on and the devices being used. Also, are you configuring a new F5?
