F5 edge client for Raspbian?
All
Is there an F5 or third party edge client for raspberry pi Raspbian?
We have an APM operating as an SSL VPN and working well for Windows Mac and i386 Linux, but wondering if anyone in F5 has compiled the client for Raspbian?
Thanks all
Glen
- Leonardo_Souza
Cirrocumulus
As far as I know there is no graphical edge client for Linux, so if you are using must be the command line (or browser but is different).
The only difference I see from the Linux i386 you said, is that Raspberry Pi uses ARM cpu. However, the documentation does limit the type of CPU that it can be used. The installation script is just a bash script that will work with any CPU, but I don't know if the other packages in the installation have CPU limitations.
Try to use and let me know the result. I have a Raspberry Pi 1, I can give a try if does not work for you.
Solution about linux client:
- Eric_Chen
Employee
There is a armhf binary that you can download to run the CLI F5 VPN client. https://devcentral.f5.com/s/articles/F5-VPN-Client-from-Raspberry-Pi. It is accessible on the BIG-IP in the same location where you can download binaries for Windows/Mac/Linux (x86) clients.
