logan92's avatar
logan92
Jan 15, 2024
f5 device certificate management
We have signed 3rd party certificate and want to replace F5 mgmt gui certificates on HA devices.
Do i just need to import new signed cert in System  ››  Certificate Management : Device Certificate Management : Device Certificate Chain  and key in System  ››  Certificate Management : Device Certificate Management : Device Key
should i follow this link https://my.f5.com/manage/s/article/K42531434#replace   ?
  • Hello logan92 ,
    In the past I had some problems updating this cert from the GUI, my recommendation is to apply both files using SSH and restart the httpd afterward. Hope this helps.
    I hope it helps you.
