tstott707's avatar
tstott707
Feb 09, 2024
F5 credential scanning not working when F5 is configured with LDAP due to failed login
When the BIG-IP appliance has its authentication configured for local login the credentials are working, but once the LDAP configuration is enabled the local login is failing. We are using an LTM with webtop as well. How do I get the credential scanning to work with the LDAP configured?
    • tstott707's avatar
      tstott707
      I have the BIG-IP's set authentication using Remote-LDAP configuration. The credentials that are being used for scanning the devices aren't being allowed to login and scan the device because of this configuration. It will only work right now if I set the authentication to local login
