Mauro_Longhi_11
Mar 06, 2014f5.citrix_vdiv1.1.0rc6 Receiver 4.1 Problems
Hi!
I have deployed iApp f5.citrix_vdiv1.1.0rc6 to pubblish Citrix Storefront 2.1. I have tried to use Webtop and Storefront portal direclty, but without success.
My problem is that I can't use Citix Receiver 4.1 because it can't connect to my public https:// site.
Are there some particular configuration to do?
Mauro Mauro
- Michael_Koyfman
Cirrocumulus
What version of TMOS are you running?
- Mauro_Longhi_11
Version 11.4.1 - Michael_Koyfman
Cirrocumulus
Have you upgraded to 11.4.1 HF3? That is the right version to be using with Receiver 4.1. Also probably worth opening a support case if you are completely stuck getting things to work. Did you read the associated deployment guide? - Mauro_Longhi_11
I have read the deployment guide. Now I can connect Receiver 4.1 using webtop. With this configuration I can't use Storefront service (favourite applications). My version is 11.4.1 HF2, but I have just installed HF3. Tonighit I'll reboot the machine. Is this the solution of my issue in your experience/opinion?
- Mauro_Longhi_11
Version 11.4.1 - Have you upgraded to 11.4.1 HF3? That is the right version to be using with Receiver 4.1. Also probably worth opening a support case if you are completely stuck getting things to work. Did you read the associated deployment guide?
- Mauro_Longhi_11
- Mauro_Longhi_11
I have update to 11.4.1 HF3, but the situation didn't change...
