Jayesh_Patel_24's avatar
Jayesh_Patel_24
Jul 13, 2017
F5 BigIP Edge Client - Help Me understand
Hello everyone, hoping you could help me out.
I am new to APM and have a virtual lab setup and playing around with APM. I am having difficulty in setting up and understanding BIGIP Edge Client. I have got the Network Access portal setup and all working, however cannot get the BIGIP Edge Client to work. Looking at the resources online, they refer me to creating a connectivity profile, but I dont understand the complete configuration. Am i suppose to associate connectivity profile to a virtual server, also what is the server IP address for the connectivity profile, if there is a document detailing the complete deployment of the F5 and Edge Client that would be great. Can someone please help me understand the EDGE Client?
Thank You
  • The server IP address in the connectivity profile is your VS IP address (or public IP address if you are NATing this first) You shouldn't need to do much to the default settings in the connectivity profile, just specify the server IP as mentioned above, then when you connect it will initiate the policy that is applied to the VS and ask for credentials if you have this set up.
