ra7oub_249484
Feb 15, 2016F5 BIG-IP Virtual Editions number of transactions per second
Hello,
I'd like to know the number of transactions per second (http tps and https tps) of F5 BIG-IP Virtual Editions. I check the datasheet of F5 BIG-IP but I don't find the information.
I will be appreciated for all your helps.
Thank you
- Kevin_Stewart
Employee
It's there on page 5 of the VE datasheet, it's just not as specific as the hardware datasheet numbers. The biggest caveat with running in a virtual environment is the commodity hardware that it runs on. F5 is giving you licensed capacity in this case, not actual (tested) throughput numbers.
