F5 Auto backup script for SCP for V10 and 11.
Hello Guys,
I have tried looking for the subjected topic within DevCentral, but unfortunately that didn't help. (I must be doing something wrong for sure). By the way I couldn't find any script for SCP which can be use for version 10.
My requirement is to craft a script for SCP server which executes on daily basis. The customer is having 2 separate clusters, one is running on v10, another on 11.
Is there any script which I can use for my requirement?
Thank you,
- ShaikhCCIE_1561
The link is down
- swo0sh_gt_13163
Altostratus
Hi All!
I have prepared a raw document, which covers all the procedures need to configure on SCP/BigIP in order to achieve the objective.
As it is very raw, any help improving the doc, would help others to achieve their requirement.
https://www.dropbox.com/s/muasd5t8mu7wu4o/F5%20Backup%20procedure%20over%20SCP.docx
In case if you modify the doc, please upload it somewhere and share the link as well.
Thank you very much you all to achieve my objective. Much appreciated!
Cheers!
- Jeff_Hollenshea
Hi, I am trying to do the opposite in a way. I want to SCP to a F5 create the latest .ucs file and then pull it back to the scp server. So basically I want the SCP server to do all commands. This will be done to multiple F5's so the name of the file needs to keep the same date and hostname as the file generated in var/tmp on that specific device. Thanks
- swo0sh_gt_13163
Altostratus
Soon I will share complete steps I have followed to achieve the Backup Automation. That might help someone.
Cheers!
- The_Bhattman
Wonderful. I am glad everything worked out
-=Bhattman=-
- swo0sh_gt_13163
Altostratus
Hi All!
Thank you very much guys for your help. I have successfully achieved the requirement!!!
I have managed to transfer backup to the SCP server. Following is the final version of the script which made it working.
!/bin/bash /admin/home/bigipbackup.sh UCS Files will be saved to /var/local/ucs/ SCF Files will be saved to /var/local/scf/ Create current date/time stamp variable DATETIME="`date +%Y_%m_%d`" Note the correct ` character must be used above, this can be found near the top left of most keyboards just under the [ESCAPE] key. Uncomment the following line for troubleshooting echo $DATETIME Create filename variable UCS_FILENAME="${DATETIME}_$HOSTNAME" Uncomment the following line for troubleshooting echo $UCS_FILENAME Create a UCS archive with the filename specified above The file extension will be .ucs � will be available in the GUI tmsh save sys ucs "${UCS_FILENAME}" Also create an SCF file with the same filename The file extension will be .scf � won�t be available in the GUI tmsh save sys config file "${UCS_FILENAME}.scf" If you don�t delete these files /var will become full fairly quickly Change the +31 value (31 days) to whatever suits you find /var/local/ucs/ �mtime 21 -delete scp "/var/local/ucs/${UCS_FILENAME}.ucs" f5-user@10.254.55.22:/home/f5-user/tmp/S1DZILB01/ EOFWithout defining the source and destination complete path, it was giving different errors. Many thanks for sharing the script, that really helped.
Cheers!
- swo0sh_gt_13163
Altostratus
Thank you very much for the script. That made my life easier. - What_Lies_Bene1
Good news, you're right about the source path, I'll know for next time. Cheers
- swo0sh_gt_13163
Altostratus
NP!
thanks again. I will share my feedback. cheers!
- swo0sh_gt_13163
Altostratus
NP!
- What_Lies_Bene1
tmsh is supported in v10 so shouldn't be a problem.
If you think it is I'd suggest you enter each command manually at the CLI and see which one is the problem. The syntax may have changed slightly between versions perhaps? There are only two so this shouldn't take long. I don't have v10 to test against unfortunately.
- swo0sh_gt_13163
Altostratus
Sure, I will. However can I use the same script for V10? It doesn't seem to be working with version 10, as it contains tmsh commands, right?
Can you please share the same script for V10?
Cheers!
- The_Bhattman
Let us know how it goes
-=Bhattman=-
