F5 11.6.0 no-platform-check not working
Hello,
I upgraded my lab environment to 11.6 and I'm in the process of migrating it off of hardware > VM, I've done it in the past with previous code levels, but ran into this issue with 11.6, has anyone else?
(cfg-sync Standalone)(Active)(/Common)(tmos) load sys ucs /var/tmp/server_import.ucs no-license no-platform-check
Replace all configuration on the system? (y/n) y
Processing UCS file: /var/tmp/server_import.ucs
Installing full UCS (11.6.0) data, excluding license file.
Saving active configuration...
The hostname is set to server.com
Extracting manifest: /var/tmp/server_import.ucs
Product : BIG-IP
Platform: UCS : Mercury
System: Z100
ERROR: The platform on the system is different from the platform in the UCS. Can't install the UCS. To bypass platform check, use no-platform-check option.
Operation aborted.7 Replies
- What_Lies_Bene1
I couldn't find anything but perhaps check out the v11.6 release notes;
http://support.f5.com/kb/en-us/products/big-ip_ltm/releasenotes/product/relnote-ltm-11-6-0.html
http://support.f5.com/kb/en-us/products/big-ip_ltm/releasenotes/product/relnote-ve-11-6-0.html
- SL
Cirrus
I am experiencing this issue on 11.6.0HF1.
Any ideas to get it working?
- nitass_89166
Noctilucent
it is bug 479359.
ID479359 Loading a UCS file with the no-platform-check option is not working
workaround is to set ucs.platformcheck db variable to false and then load ucs without no-platform-check.
otherwise, you may open a support case to see if they can provide engineering hotfix.
- SL
Cirrus
thanx nitass, updating db worked perfectly
- nitass
Employee
it is bug 479359.
- SL
Cirrus
- Héctor_J__Sánc1
Have you tryed to invert the order of the parameters?: load sys ucs /var/tmp/server_import.ucs no-platform-check no-license
