Extract info via Rest from BigIQ.
Hi all,
We are currently in the middle of a migration from VCMPs to VE's and from EM to Big-IQ.
Currently we do billing by of connections and we track this in the description field with other relevant info delimited by spaces.
We extract this information via a shell script that queries the EM database and then parses the output into a CSV file that is then periodically imported into our billing system. This script was set up before my time and do not have the time or the will to try and modify it to work with Big-IQ.
When we move to Big-IQ we will not be able to do this.
What I do have the will to do is to attempt to implement what I think would be a more "future proof" way extracting this information. So I was thinking about the RESTAPI.
I am a complete beginner when it comes to this sort of thing and was wondering if anyone could point me in the right direction.
I was looking at the python SDK and was wondering if this was a good place to start?
Thanks, Jeramy
- Madhu_Rajagopa1Historic F5 Account
Can you give specifics of what info you are trying to retrieve over the REST API?
- PeteWhite
Employee
You should definitely be considering using REST for this - as you say the SDK is easy to use, or I have a simpler Python module called iCR that you can use. Use a simple database table to store the device details and periodically retrieve the number of connections per VS then output it into a CSV. Simples!
- allenderj
I actually worked this out with the SDK. Ill post my code below for others to get ideas from, I am not a programmer by trade but I can make things work if I need too so the code is not the most elegant. I am sure it could be improved but it is working for my needs. It runs on a cron job and then another cron job takes the output and imports it into a database that our billing software uses.
Thanks, -J
!/usr/bin/python Import Regex module import re Import Datetime and parser for date normalization import datetime from dateutil import parser Import F5 SDK from f5.bigip import ManagementRoot This gets rid of the warning message about SSL certificate issues. import requests.packages.urllib3 requests.packages.urllib3.disable_warnings() Read from the list Big IPs to query load it into the bigip list. with open("/home/f5_billing/load_balancing/bigip")as f: bigip = f.read().splitlines() Open csv file for modification file = open('/home/f5_billing/load_balancing/load_balancing.csv', 'w+') Write the CSV headers to the load_balancing.csv file Billing Code, Start Date , Notes and Quantity are all part of the description field file.write("instance_id,agency,region,name,ip_address,port,account_number,quantity,date_start,notes\n") Declare global variable instane_id to increment through for the database primary key instance_id = 1 loop to query each server in the list for server in bigip: mgmt = ManagementRoot( server, "username", 'password') vservers = mgmt.tm.ltm.virtuals.get_collection() Loop through the contents of the current servers API output for vs in vservers: Parse through the description of the VIP to extract billing code, Billable Units, date installed and the notes. d = vs.description desc = [] desc = d.split(" ", 3) desc.append ("") billing_code = desc[0] billable_units = desc[1] install_date = desc[2] Parse through the date to normalize it install_date = parser.parse(install_date) install_date = install_date.strftime("%Y-%m-%d") notes = desc[3] Check to see if there is a notes entry if len(desc[3]) > 0 : notes = desc[3] else: notes = "No Notes!" Define the s list, this will be what is printed to the CSV file s = '' appende the instance id and then increment it by 1 instance_id = str(instance_id) s += instance_id + ',' instance_id = int(instance_id) instance_id = instance_id + 1 create and append a blank value for agency agency = " " s += agency + ',' append the partition s += vs.partition + ',' Append the Virtual Server Name to the s string s += vs.name + ',' Split the destination and append the VIP address and VIP port to the s string The split is nessecary bacause there are seperate fields for ip address and port de = vs.destination dest = de.split(":", 1) vip_address = dest[0] vip_port = dest[1] Extract IP address from the vip_address so that the route domain or partition is not mentioned (cosmetic) vip_address = re.search(r'\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3}', vip_address).group() s += vip_address + ',' s += vip_port + ',' s += billing_code + ',' Append the billiable units to the s string s += billable_units + ',' Append the start date to the s string s += install_date + ',' Append the notes to the s string and create a new line s += notes + '\n' Write the s string to the load_balancing.csv file at end of loop interation. file.write(s) Close the file after the loop has exited file.close()- PeteWhite
Employee
Brilliant! Good job in posting, i'm sure it'll help others
