External SFTP monitor
How can i configure external SFTP monitor on LTM?
- jpeterson6_1656
Please follow my question on the same topic - It should have most of the details you seek. Feel free to ask additional questions if needed!
- b_kodan_313047
Thanks for the quick update. Went through the link and i have couple of queris; 1. How do we authenticate the user'sftpMonitor' which is mentioned in the sftp monitor script. 2. What are the commands added in the batch file 'sftpmonitor.input'. 3. Assume user 'sftpmonitor' has to be created in both LTM as well SFTP server?
- jpeterson6_1656
The best source of info that helped me as to how to authenticate without a password is here: http://www.jscape.com/blog/setting-up-sftp-public-key-authentication-command-line
The commands in the input file are only 'dir' and 'bye'. The grep in the script (for 'IB') is just pulling out one of the subdirectories/folders that show up in stdout when the 'dir' command is executed.
The user sftpMonitor does not need to be created on LTM, just the SFTP server. The public key is attached to that username in the servers' user profile (details in link on 1)
- b_kodan_313047
Thank you so much.
So you have created 'sftpMonitor' and '.ssh' folder undere home?
As per the document, public and private key has to be created under '/home/user/.ssh'.
Please correct me if i am wrong?
