  • JG's avatar
    JG
    That means you only need an HTTP monitor.
    You can create a custom monitor for the SMTP server, specifying the following:
    Type: HTTP
    Send String: "GET /BroadcastState/Default.aspx?obj=Smtpbackendserver HTTP/1.0\r\nHost: x.y.z.com\r\n\r\n" (No quotes)
    Receive String: yes
    Alias Address: IP address of x.y.z.com
    Alias Service Port: 80
  • JG's avatar
    JG
    Not sure why you need an external but here's one based on /config/monitors/sample_monitor anyway:
    !/bin/sh
     (c) Copyright 1996-2006, 2010-2013 F5 Networks, Inc.
     This software is confidential and may contain trade secrets that are the
     property of F5 Networks, Inc.  No part of the software may be disclosed
     to other parties without the express written consent of F5 Networks, Inc.
     It is against the law to copy the software.  No part of the software may
     be reproduced, transmitted, or distributed in any form or by any means,
     electronic or mechanical, including photocopying, recording, or information
     storage and retrieval systems, for any purpose without the express written
     permission of F5 Networks, Inc.  Our services are only available for legal
     users of the program, for instance in the event that we extend our services
     by offering the updating of files via the Internet.
     @() $Id: //depot/maint/bigip11.6.2/tm_daemon/monitors/sample_monitor1 $
     these arguments supplied automatically for all external pingers:
     $1 = IP (::ffff:nnn.nnn.nnn.nnn notation or hostname)
     $2 = port (decimal, host byte order)
     $3 and higher = additional arguments
     $MONITOR_NAME = name of the monitor
     In this sample script, $3 is the regular expression
     Name of the pidfile
    pidfile="/var/run/$MONITOR_NAME.$1..$2.pid"
     Send signal to the process group to kill our former self and any children
     as external monitors are run with SIGHUP blocked
    if [ -f $pidfile ]
    then
       kill -9 -`cat $pidfile` > /dev/null 2>&1
    fi
    echo "$$" > $pidfile
     Remove the IPv6/IPv4 compatibility prefix
    node_ip=`echo $1 | sed 's/::ffff://'`
     Using the nc utility to get data from the server.
     Search the data received for the expected expression.
    echo "GET /" | /usr/bin/nc $node_ip $2 2> /dev/null | grep -E -i $3 > /dev/null
    echo "GET /BroadcastState/Default.aspx?obj=Smtpbackendserver HTTP/1.0\r\nHost: x.y.z.com\r\n\r\n" | /usr/bin/nc ip_addr_of_x.y.z.com 80 2> /dev/null | grep -E -i "yes" > /dev/null
    status=$?
    if [ $status -eq 0 ]
    then
     Remove the pidfile before the script echoes anything to stdout and is killed by bigd
        rm -f $pidfile
        echo "up"
    fi
     Remove the pidfile before the script ends
    rm -f $pidfile
    You need to add the monitor name, host name and IP address where necessary.
