pallocca_73085
Mar 16, 2011external data group and findclass
I will be opening a case with F5 but I am sure it will get solved faster here :)
I have an external data group object (type string) that looks like this -->
Peter Bigshot , Pool-a
Nicky Bigbucks , Pool-b
Anthony Bigtime , Pool-c
in my iRule I am parsing HTTP payloads to grab a username and them looking up the data group to find a pool name. My problem is I am not getting anything back. Here is my query -->
set datapool [findclass $username $::external_data ","]
I am expecting to get "Pool-a" retuned if I provide "Peter Bigshot".
I am running BIG-IP 9.2.5 Build 5.1.
- pallocca_73085
I found my 1st issue already.
When loading the object the BIG-IP is stating an invalid format for the file.
I have tried using a ":" instead of a "," as the delimiter as well as adding the delimiter to the end of each line. no luck. - hoolio
Hi Pallocca,
Can you try this format for the external datagroup in 9.x:"Peter Bigshot:Pool-a", "Nicky Bigbucks:Pool-b", "Anthony Bigtime:Pool-c",
Aaron - pallocca_73085
worked like a charm. thanks!
