romio28's avatar
romio28
Jan 12, 2023
Export/Import ssl certificate from python f5-sdk
How to automate the export/import of ssl certificates from python sdk?
 Thanks in advance.
  • Hi try below script
    import f5-sdk
    mgmt = f5-sdk.ManagementRoot("<IP_ADDRESS>", "<USERNAME>", "<PASSWORD>")
    # Import a certificate and key from drive
    mgmt.ssl.import_key("D:\\<CERTIFICATE_FILE>", "D:\\<KEY_FILE>")
  • xuwen's avatar
    xuwen
    Export the key and crt contents of the certificate in the system. There is no quick interface. The key and crt files are stored in:
    /config/filestore/files_ d/Common_ d/certificate_ d/
    /config/filestore/files_d/Common_d/certificate_key_d/
    you can use the until.bash interface of the api to execute the cat command to view the corresponding file contents
    Here is code to import local desk crt and key to F5:
    from f5.bigip import ManagementRoot
    mgmt = ManagementRoot('192.168.100.7', 'admin', 'xt3211@2020')
    client_crt_name = 'gtm-client.crt'
    client_key_name = 'gtm-client.key'
    try:
        mgmt.shared.file_transfer.uploads.upload_file(
                                        filepathname=r'C:\Users\xuwen\Documents\{}'.format(client_crt_name),
                                        target=client_crt_name)
    except Exception as e:
        print('import {} to F5 /var/config/rest/downloads/ failed, reason is '.format(client_crt_name) + str(e))
    try:
                                        filepathname=r'C:\Users\xuwen\Documents\{}'.format(client_key_name),
                                        target=client_key_name)
        print('import {} to F5 /var/config/rest/downloads/ failed, reason is '.format(client_key_name) + str(e))
    else:
        # create crt and key in GUI Web System  ››  Certificate Management : Traffic Certificate Management : SSL Certificate List
        if mgmt.tm.sys.file.ssl_certs.ssl_cert.exists(
                name=client_crt_name,
                partition='Common') is False:
            try:
                mgmt.tm.sys.file.ssl_certs.ssl_cert.create(
                    partition='Common',
                    sourcePath='file:/var/config/rest/downloads/{}'.format(
                        client_crt_name))
                print('create crt in GUI Web System  ››  Certificate Management : '
                      'Traffic Certificate Management : SSL Certificate Listt {} failed!'
                      ' reason is: '.format(client_crt_name) + str(e))
            try:
                mgmt.tm.sys.file.ssl_keys.ssl_key.create(
                    name=client_key_name,
                    partition='Common',
                        client_key_name))
                print('create key in GUI Web System  ››  Certificate Management {} failed! reason is:'
                      ' '.format(client_key_name) + str(e))
    • romio28's avatar
      romio28
      It works as admin role but I cat upload files as Certificate Manager, it’s a big security issuefor us!
      Any idea to solve the problem?
      thanks
