Panki_308017's avatar
Panki_308017
Nov 03, 2017
Explain receive string and receive disable string?
RCV string and RCV disable string relation in order to mark pool member as UP and DOWN ?
  • nathe's avatar
    nathe
    Panki, may I refer you to the following solution k12818
    This should explain how the receive string and receive disable string work and, additionally, work together. Essentially the receive string will be used to mark a pool member Up and the receive disable string is used to mark a pool member down.
    Hope this helps,
    N
