Wales_113331's avatar
Wales_113331
Jul 05, 2018
Exchange 2016 Behind LTM Deployment Help
I have just used the F5 iapp template to configure the F5 for exchange 2016. I am facing two issues 1. Authentication happens twice, via the F5 form and then the exchange form itself. 2. Unable to setup outlook completely. Did a fiddler check, the autodiscover stage was fine, but it gets stuck at mapi during the setup, with a message that user must-revalidate.
Authentication is basic. Stuck on this all day, any help would do, i have gone through threads on similar issues but it hasn't gotten me anywhere.
  • this is tricky to trouble shoot via a forum, specially such broad issues without any errors, logging or pointers.
    which iapp version did you use? which settings on the parts that matter for your issues, so the OWA part and the OA part.
    the two times login points to SSO failing, set APM logging profile to debug and check the APM log for clues.
