Exchange 2010 health monitor difference between iApp and deployment guide
Hello, Which iAPP and DG are you using? I have copied the link to the latest dg for Exchange 2010/2013. http://f5.com/pdf/deployment-guides/microsoft-exchange-iapp-dg.pdf. The question in the iAPP under the Server health Monitors section Asks if you would like to use simple or advanced monitors. If you are looking to only monitor via a simple http(s) monitor then then select that option. The advanced monitor utilizes an EAV monitor and logs in with a "user" account to test access to the backend mailbox database. Are you trying to utilize the manual setup and not clear on what should be in the Send/Receive string or are you wanting to use the iAPP and feel the DG is inaccurate with what the iAPP is creating for monitors?
