Akira_Izawa_856
Sep 20, 2005Exception of System.Xml.XmlTextReader.Boolean Read()
When I create iControl application by using .NetFramework(C), sometimes the exception of System.Xml.XmlTextReader.Boolean Read() comes in API extension. The enviroment of this phenomenon is showed below. (This problem occurs so rarely.)
Generated API:
LocalLB.PoolMember.get_session_enabled_state
LocalLB.PoolMember.get_ratio
LocalLB.Pool.get_member
Example of argument: value of string[]
- Akira_Izawa_856
I am so sorry for my unfinished question I have posted. I made mistake typing. I post my question again.
Generated API:
QA_TEST_POOL
P100
QA_TEST_POOL_Part2
TestPool999
Exception
classification: XmlException
message: The root element is missing.
If you have any idea about the reason for this phenomenon, please let me know.
Thank you. - This error would indicate that an empty SOAP response is returned from the server. This is different than the condition of a server fault where a HTTP 500 error would be returned and caught by the client application at the transport level.
We have not witnessed this behavior here before in development or testing. Is there a way you can reproduce this or is it somewhat random? - Akira_Izawa_856
I also can not reproduce this phenomenon. It seems like random. I am not sure with the conditions I told you yesterday, this exception will be come. If I can indicate the conditions, I will let you know.
Thank you for your help always,
