Entrust SSL Chaining problems today??
Has anyone noticed any problems with EV certificates that are issued by Entrust starting yesterday or today? Perhaps an issue with a microsoft patch. I don't believe it to be an F5 issue but just wanting to see if anyone else is seeing this
- Christopher_Boo
What exactly are you seeing? I use Entrust and can try to reproduce.
Chris
- Mike_61719
Cirrus
There was a patch released a few days ago for Windows, believe it was March 10th. KB931125
- Christopher_Boo
- Mike_Maher
Here is the release from Entrust, if you have a prior copy of the EntrustL1E certificate that is bundled to the old certificate you probably want to replace it with a copy of just the L1E cert or bundle it with the correct chain. This issue appears sporadically, because if you visit a site that has corrected their chain it should correct you for all sites.
http://www.entrust.net/knowledge-base/technote.cfm?tn=8780
- Mike_Maher
Note of caution if you have a site that has web logic servers connecting to it you need to use the bundle or the web logic connectivity will fail.
