Robert_47833
Altostratus
Jul 15, 2013enable ssl serverside for specific uri
I don't want to enable ssl profile of server side in virtual server
but I want to enable ssl server side for some url ,such as /xyz
how to achieve this?
- nitass
Employee
you have to assign serverssl profile to virtual server but disabling/enabling it in irule.
e.g.[root@ve10:Active] config b virtual bar list virtual bar { snat automap pool foo80 destination 172.28.19.252:443 ip protocol 6 rules qux profiles { clientssl { clientside } http {} serverssl { serverside } tcp {} } } [root@ve10:Active] config b pool foo80 list pool foo80 { members 200.200.200.101:80 {} } [root@ve10:Active] config b pool foo443 list pool foo443 { members 200.200.200.101:443 {} } [root@ve10:Active] config b rule qux list rule qux { when HTTP_REQUEST { SSL::disable serverside if { [HTTP::uri] starts_with "/xyz" } { SSL::enable serverside pool foo443 } } } [root@ve10:Active] config curl -Ik https://172.28.19.252/ HTTP/1.1 200 OK Date: Tue, 16 Jul 2013 14:23:30 GMT Server: Apache/2.2.3 (CentOS) Last-Modified: Thu, 23 May 2013 00:28:46 GMT ETag: "4185a8-59-c3efab80" Accept-Ranges: bytes Content-Length: 89 Connection: close Content-Type: text/html; charset=UTF-8 [root@ve10:Active] config curl -Ik https://172.28.19.252/xyz/ HTTP/1.1 200 OK Date: Tue, 16 Jul 2013 14:23:33 GMT Server: Apache/2.2.3 (CentOS) Last-Modified: Tue, 16 Jul 2013 14:22:22 GMT ETag: "468841-59-b48d8380" Accept-Ranges: bytes Content-Length: 89 Connection: close Content-Type: text/html; charset=UTF-8 - Robert_47833
Altostratus
actually I tried this one
when CLIENT_ACCEPTED {
pool foo443
will this work?what is the difference between this one and yours? - Robert_47833
Altostratus
this is the vip config
virtual srwd33-www {
mirror enable
snat automap
destination 10.10.10.10:http
ip protocol tcp
rules test-irule
profiles {
http {}
oneconnect {}
serverssl {
serverside
tcp-lan-optimized {
serverside
tcp-wan-optimized {
clientside
irule test-irule before "it has intermittent issue which goes to fallback host if I want to hit default-pool
if { [HTTP::uri] starts_with "/test1" } {
pool xyz
return
else {
pool default-pool
test-irule after:it is fine
when SERVER_CONNECTED priority 10 {
if { [LB::server pool] eq "xyz" }{
else {
pool xyz
return
else {
pool default-pool
I want to know the root cause and which way is recommended - nitass
Employee
irule test-irule before "it has intermittent issue which goes to fallback host if I want to hit default-poolis it possible that there are multiple http requests in one tcp connection which some is https (xyz) and some is http (default-pool)?
- Robert_47833
Altostratus
hmmm,I am not sure
it is just non-keepalive connection for this vip
everytime I use one url to test,sometimes it works fine,sometimes it hit fallback host
in tcpdump ,I found F5 send encrypted data to default pool
