Abhilash_Paul_2's avatar
Abhilash_Paul_2
8 years ago
Enable source IP persistence based on X forwarded IP info
I am looking to enable source ip persistence on Virtual server A based with X forwarded IP information sent by another Virtual server B. both virtual server residing on different F5s
My architecture is virtual server A(Internet facing F5) ---> Linux revers proxies--> virtual server B (Internal F5)---> Actual pool members
Any help highly appreciated
  • Hello Paul,
    You can do it by different manner. One of them consist of :
    1) From VS_A : Add the "X-Forwarded-For" header using either the HTTP profile or by adding an irule that insert this header.
    HTTP::header insert X-Forwarded-For [IP::remote_addr]
    Reference : https://support.f5.com/csp/article/K4816
    2) From VS_B : You will need to add the following irule, that will use "Universal persistance" on XFF header
        set clientip ""
        if { [HTTP::header exists "X-Forwarded-For"] } {
            set clientip [HTTP::header "X-Forwarded-For"]
            set clientip [IP::client_addr]
        persist uie $clientip
    when HTTP_RESPONSE {
        persist add uie $clientip
    Reference : https://devcentral.f5.com/questions/universal-persistence-with-x-forwarder-47038
    Please give us a feedback.
    Hope it helps
    Regards
  • Robin1's avatar
    Robin1
    Hi Abhilash, is your issue resolved? I am on the same boat, tried all possible scenarios still not working.
