Fluidetom_12222's avatar
Dec 21, 2016
emerg logger: Re-starting logstatd
Hey Guys,
Each time I connect via SSH to the F5 I get the following error message multiple times. Would you have an idea on how to fix this?
  • Can you console into the unit and check for any core dump files? Have you run a qkview and uploaded to ihealth or opened a case with the qkview? this will help analyze the error messages you are seeing.
  • Hi Fluidetom
    you can take a qkview and upload to Ihealth and under diagnostics tab check if it says that you have any core file being dump it will tell you when it was generated and where the core file is. if you find any core file then you will need to raise a case and upload the core file for further analysis.
    for logstatd error msg you can do clsh bigstart restart logstatd Note clsh should be used when you have viprion chassis
