emerg logger: Re-starting gtmd after gtm_add
hi all,
ran into a problem when i was doing a simple GTM setup.
site 1 F5 information
platform 3900 self ip 10.10.10.xport lock down allow all listener ip 10.10.10.x(nat on gateway) -> 118.189.55.x
site 2 F5 information
platform 2000 self ip 192.168.255.x port lock down allow all listener ip 192.168.255.x (nat on gateway) -> 61.8.230.x
procedure that i did.
after preparing the LTM portion on the site 1 GTM bigip_add the self ip of LTM at both site big3d_install the self ip of LTM at both site
create the datacenter object (2 DC) create the server object (2 LTM object) create VS object in each server
do a GTM add site 1 GTM ip address from the site 2 GTM
the moment i did the gtm_add, the gtmd start restarting itself constantly. a core file was generated by the name gtmd.bld5.0.429.core.gz
if i issue the command esrapmtg -l -k and remove the gtm configuration, then everything becomes ok. once i do an add again, the problem comes back.
Has anyone met the above issue before? Appreciate any advise given. cheers
- VernonWells
Employee
I strongly recommend that you open an F5 Support case.
- henrykay_191137
hi vernon,
have raise a support case and will be working with support on this.
