private55_12056's avatar
private55_12056
Jul 07, 2016
Solved
EM - how to search configuration using CLI ?
Hello,
in the EM web GUI I can search configuration using:
Enterprise Management -> Configuration -> Search configuration
Can I do similar using CLI/tmsh ?
Best regards
  • No. EM does not recommend searching the configuration in CLI due to the fact that it stores all the delta in SQL tables.
    /Amanpreet
    /Amanpreet
