Songseajoon_222
Mar 06, 2016edit sender number at OTP
And the use of APM, are sent using HTTP clickatell of the OTP.
However, it appears to be sending a fixed number of OTP number. Can you modify that number?
can you help edit phone number Not a recipient number, sender number
sorry, I cant speak english well
- Faruk_AYDIN
Altostratus
You must create a Sender ID on clickatell. After that, in configuration of AAA Server of clickatell in APM set a new Hidden Form Parameters/Values like that :
from=MySenderIDHow to create Sender ID links are :
https://www.clickatell.com/downloads/Clickatell_Sender_ID_User_Guide.pdf
