Lokesh_R's avatar
Lokesh_R
Feb 27, 2019
Edge client compatability
Planning to upgrade 11.5.4 to 13.1.1 need to know whether i need to update my edge client VPN version also ?.
Please advise
  • Once user connects to your virtual server using VPN edge client, it will automatically update the new client version.
    • Lokesh_R's avatar
      Lokesh_R
      could you please provide any document related to this
    • Lokesh_R's avatar
      Lokesh_R
  • Please refer below article:
    https://support.f5.com/csp/article/K15302
    The successful automatic update of the BIG-IP Edge Client application and components depends on any of the following conditions:
    The BIG-IP APM or Edge Gateway system is upgraded, and the BIG-IP Edge Client or BIG-IP Edge Client components are updated. When the user device installed the BIG-IP Edge Client configuration, the installation had the automatic update feature (Component Update) set to yes (default setting).
    • Lokesh_R's avatar
      Lokesh_R
      If I upgrade BIG-IP Edge Client components only to 7160 , BIG-IP APM 11.5.3 will support the client version.
    • Lokesh_R's avatar
      Lokesh_R
