demmo_251289's avatar
demmo_251289
Nov 17, 2016
Easy way to enter hundred of redirects
Which is the easy way to enter hundreds of redirects into BigIP without entering line by line ? can we upload a file ?
  • Yes.
    On the Main tab, click System > File Management > iFile List > Import
    That will provide it as an iFile, but you haven't provided any use case once the file is uploaded so iFile might not be what you're after.
    • demmo_251289's avatar
      demmo_251289
      I created a Data Group List and I can see I have the option to import a file. Do you know what format the file should have or is there an example somewhere ?
    • ekaleido_26616's avatar
      ekaleido_26616
      It can have any format, but if you want to use it in an iRule (to compare one path and redirect to another) I think you'd be better served formatting it like a datagroup and copying it into your bigip.conf.
  • Yes.
      demmo_251289
    • ekaleido's avatar
      ekaleido
      Icon for Cirrus rankCirrus
