Dynamic Ratio load balancing in order to load balance my traffic based on the CPU questions?
Dears,
I want to configure a Dynamic Ratio load balancing for my web servers in order to load balance my traffic based on the CPU, memory utilization of the servers and as I have understood that snmp_dca monitor is responsible about pooling the required information of CPU and memory from the servers.
I have two questions as follows:
1- snmp_dca health monitor is a node based monitor enabled under the node health monitor but not available per pool so I was wondering if enable it under the node will be enough and dynamic ratio load balance will be able to use the health monitor (snmp_dca) enabled under the node without having the option to enable it under the pool? Or we should have a way to enable it under the pool?
2- Do we need a SNMP agent installed in the windows 2008R server to enable the snmp_dca monitor works properly with the server or SNMP agent is enabled by default in windows 2008 server?
Thanks in advance for your help.
Regards, Muhannad
- mikeshimkus_111Historic F5 Account
Hi Muhannad, you'll need to use Dynamic Ratio (Node) load balancing at the pool level after you've applied the monitor at the node level.
I think you'll need to install SNMP on your server: http://blog.skufel.net/2012/09/how-to-adding-snmp-to-windows-server-2008-r2/
In case you don't want to install SNMP, F5 also provides detailed instructions on using WMI monitors for Dynamic Ratio LB here: https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ltm-concepts-11-5-0/21.html?sr=35364066
Mike
- Muhannad_64809
Hi Mike,
Thanks for your response.
i am wondering if LTM using any Community strings and how we can configure it, so it will be able to accesse the information on server via SNMP?
Regards, Muhannad
