Dropped connection statistics- LTM 11.5.1
In the statistics of a VS or a Pool i can find details on 'Current Connections' or 'Total Connections'. Is there an option or command to see the connections that hit a VS and got dropped and number of connections dropped by a Pool??
Looking to see if there is a dropped connection statistics somewhere.
- Max_Q_factor
Cirrocumulus
If you are using a 11.x version of BIG-IP, then you should be able to find a lot of information about connections through the specific profiles that are applied to the virtual server.
Let us say you have the tcp-wan-optimized profile for your clientside tcp profile.
If you go to the statistics for the virtual server and have that profile selected under Profiles > Select Profile then you can see a lot of useful information including things like:
Open Accepted Not Accepted Established Failed Expired AbandonedIf you have a HTTP profile attached to the virtual server, then you can select that and see statistics like:
Requests GET POST Version 0.9 Version 1.0 Version 1.1 Max Requests Per Connection Total Responses Successful Redirection Client Errors Server Errors Version 0.9 Version 1.0 Version 1.1Other profile types will display additional information as well.
