Does not work HSL
Hi guys
I have a question
I configured HSL but not working
I check https://support.f5.com/csp/article/K50040950#cu document
HSL server not inculde "Vlan Group self ip"
I post irule
and configuration of device please inform to me if you know problem
when CLIENT_ACCEPTED {
# DEBUG On/Off : 1/0
set DEBUG 0
set hsl [HSL::open -proto UDP -pool p_hsl_svr]
HSL::send $hsl "P-Int-Svc-SSL Dst IP [IP::local_addr] is registred on bypass_dst-ip list\n"
log Destinations
sys log-config publisher hsl_svr_pub {
destinations {
hsl_svr { }
log publisher
destinations {
hsl_svr { }
Are you running HSL via your mgmt interface or via a TMM interface?
Is the pool up?
Is the log server reachable from the BIG-IP?
Cheers,
Kees
I want to using mgmt port
I configured destination and publisher
but not forwarding .. and remote syslog is working well
thank you
