touch_93816's avatar
touch_93816
May 04, 2011
Distributing the traffic base on the port
Hi All
I am facing some difficulty about generating IRule to distribute the traffic to different destination hosts but I can not make it work and really hope you could help me.
My scenario is
I have one server on Vlan98 and its IP is 192.168.98.2
There are some other two servers on different vlan 96. Let's say 192.168.96.2 & 192.168.96.3.
Now I want to make all these servers can communicate with each other. So I have created a virtual server 192.168.98.3 and sign a pool which has two nodes 96.2 and 96.3 in it to this VS.
What I want to achieve is ssh from 98.3 to other two servers on different Vlan with different port number. My Irule is below:
when CLIENT_ACCEPTED {
switch [TCP::server_port] {
"2222" { pool TempPool member 192.168.96.2 22 }
"3333" { pool TempPool member 192.168.96.3 22 }
But this irule does not work. So could you please give me a hand?
Thank you and looking forward to see your reply.
  • hoolio's avatar
    hoolio
    Try changing TCP::server_port to TCP::local_port. In the CLIENT_ACCEPTED event, no serverside connection has been established yet, so TCP::server_port isn't a valid command in this context. If you want to check the client's destination port, it's LTM's local port. See the wiki page for a bit more info:
    http://devcentral.f5.com/wiki/default.aspx/iRules/tcp__local_port
    You could also use forwarding virtual servers to do this without destination address or port translation:
    BEST PRACTICE: SOL7229 - Methods of gaining administrative access to nodes through the BIG-IP system
    http://support.f5.com/kb/en-us/solutions/public/7000/200/sol7229.html?sr=14231306
    Aaron
  • Hi Aaron
    Thank you very much for your quick reply. I have tried the local_port but it does not work either. Now I am looking into another option. Could you please let me know is there any thing I can use to make it work if I want to use "port"?
    Thank you again and looking forward to see your reply.
  • hoolio's avatar
    hoolio
    What happens when it doesn't work? Do you get an error when trying to save the iRule? Or when you attempt a connection? Can you check /var/log/ltm for any runtime TCL errors? If you don't see any errors, can you post an anonymized copy of the 'b virtual VS_NAME list' output?
    Thanks, Aaron
