ramann_75062
Jul 13, 2009Disable CC data for POST requests
Hi @all,
its me again :-)
Today, i am looking for a way to deactivate the CC check only for POST requests - is this possible?
My first idea was, to do this via an iRule - if a POST requests, than switch to another V-Server with a different ASM policy, but i am not sure is this a good way
Bjoern
- hoolio
Hi Bjoern,
I can't really see the value in only applying the attack signature to response content for non-POST requests. Chances are the only vulnerability within an application which would lead to credit cards being leaked in response content would be from POST requests. So why would you want to disable the check for POST requests and not all requests?
If you do want to do this an iRule and second policy would be an option. You could use the 'HTTP::class select' command (Click here) to select a second HTTP class for POST requests. Note the second HTTP class must also be added to the virtual server in order to select it using HTTP::class. Selecting a second virtual server would work, but unnecessarily add the need for a second virtual server.
Aaron - Ido_Breger_3805Historic F5 AccountHi Bjoern,
Like Hoolio said, most of the vulnerabilities today on the web are within POST requests, can you please share with us why would you want to do something like that? - ramann_75062
reason is, that in the reporting, the POST requests which include CC data is marked as "Information Leakage Detected".
thanks
Bjoern - Ido_Breger_3805Historic F5 AccountHi,
Are you sure that the website doesn't really leak credit cards numbers?
ASM validates that the string of numbers is actually a real credit card using a special algorithm.
Which ASM version you are using? 9.X or 10.x? - ramann_75062
we using BIG-IP 9.4.6 Build 401.0 Final.
In this POST request, a customer send his CC data to buy something - the data he gets back is coded with stars
Here is a log extract - no, this CC is not real :-)
----Log-----
Full Request
POST /cgi-bin/payment.dll HTTP/1.1
Content-Length: 244
Content-Type: application/x-www-form-urlencoded
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7
Accept-Language: de-de
Cookie: webshop=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; HAHAHA+Deutschland_time=04045; CTG=1247133160; WSS_GW=V1z%BC@%B@riQ; s_nr=1247128127629; TSb9eef2=3f02746cdc4e67515cea09c98b1dccc048635239d4b8ba714a55bdc9; CP=null*
Referer: https://staging.testland.ha/cgi-bin/customer.dll
User-Agent: Mozilla/5.0 (Windows; U; Windows NT 5.1; de; rv:1.9.0.11) Gecko/2009060215 Firefox/3.0.11
X-Akamai-CONFIG-LOG-DETAIL: true
TE: chunked;q=1.0
Connection: TE
Akamai-Origin-Hop: 1
Via: 4.0 asi_server, 1.0 akamai.net(ghost) (AkamaiGHost)
Accept-ESI: 1.0
X-Forwarded-For: 127.0.0.1
Host: myhost.test.nowhere
Pragma: no-cache
Cache-Control: no-cache, max-age=0
Connection: keep-alive
Number: 88.79.247.30
akamaisession: candidate
Letter: second
X-Forwarded-For: 88.221.4.9
&action=payment&errordoc=globalError&kreditkarteInhaber=Fred%20Test&sent.y=0&sent.x=0&kreditkarteNummer=6677880000000004&sent=sent&affiliate=EVE&zahlungsart=2&kkMonth=02&kkYear=2012&fun=customer&nextdoc=summary&doc=payment&kreditkarteCvc=123
+ - Response
Response not found
Referrer Object
No records to display.
Cookie Name Cookie Value Reason
Parameter Name=Value Parameter Violations Parameter Level
XML Violation XML Buffer Description
Signature Name Signature ID Learn Alarm Block Context
Evasion Technique Detected Context
Pattern Context
Credit Card NumberkarteNummer" value="6677880000000004" />
HTTP Protocol Compliance
Support IDTime
170052960248913480132009-07-09 11:53:21 - Ido_Breger_3805Historic F5 AccountHi,
How the response look like?
In version 10 you can configure exceptions for the DataGuard using a regexp, however, I suggest to be careful to do so in your case. - Ido_Breger_3805Historic F5 AccountI suggest to be careful since it seems that in your case, there is a high probability that teh application leaks credit cards numbers.
- ramann_75062
The response:
Kreditkartentyp VISA
Kreditkarten-Nr. ************0004
Gültigkeit 02/2014
For me, it looks like that the WAF interpret the POST data as the "Information Leakage Detected" and not the response of this POST.
This does not make sense, the webserver need the complete data for the payment - no data, no selling :-) - Ido_Breger_3805Historic F5 AccountDataGuard is only working on response data. Please look at the responses of that page.
- Ido_Breger_3805Historic F5 AccountThe DataGuard doesn't touch or change anything in the request. It simply makes sure that sensitive information isn't leaked in responses.
