Venkata_Narayan's avatar
Venkata_Narayan
Sep 21, 2018
Difference in Blocking options in Policy Building Settings and Blocking Settings button
Hi Team,
In the ASM portion under the Learning and Blocking settings Page, we have options to block the violations under policy building settings and there is separate button blocking settings. We also some violation are not seen in policy building settings but in seen when open the blocking settings button. Can you help us explain what is the difference between these two.
  • If you click the Blocking Settings button you should see the master list of all violations. You can change the learn and alarm settings from a single location--without having to navigate the expanding menus on Learning and Blocking Settings page. If the policy is in blocking mode, you can change the blocking setting on the master list as well. If violations appear in the master list but not on the Learning and Blocking settings page it means that a custom violation was created and added to the policy. Does that help?
