N_67263
Aug 27, 2013Difference between health monitor using "http" and "tcp port-80"
Folks,
The use case I have is we have a pool configured with 2 nodes in it and has the health monitor set as http. There was some testing going on on one of the nodes and the pool was showing as...
nitass
Employee
Aug 27, 2013how can we technically explain the difference while configuring a health monitor as "http" and as "tcp-port 80". What could be the reason that the pool was up when I switches over to TCP-80?
i guess no send/recv string is configured in tcp-port 80 monitor, isn't it? if yes, tcp-port 80 monitor does not check response but http monitor does.
Troubleshooting Ltm Monitors by Aaron
https://devcentral.f5.com/wiki/advdesignconfig.TroubleshootingLtmMonitors.ashx
sol3224: HTTP health checks may fail even though the node is responding correctly
http://support.f5.com/kb/en-us/solutions/public/3000/200/sol3224.html
